Jens
2 years agostrange DCFIFO behavior
Simulation of DCFIFO shows different behavior for the same IP. Once data appear at FIFO output after one clock another time after two clocks. Is this only a problem with the simulation or does it al...
ShengN_altera
2 years agoHi,
There's no problem with the waveform if check the user guide page 19.
For Timing 2, wrreq is asserted at clock 11th rising edge while for Timing 1 the wrreq is asserted at clock 4th rising edge. If assert the wrreq at even clock rising edge any different?
Sheng
