Jens
2 years agostrange DCFIFO behavior
Simulation of DCFIFO shows different behavior for the same IP. Once data appear at FIFO output after one clock another time after two clocks. Is this only a problem with the simulation or does it al...
Jens
2 years agotiming1 and timing2 are in the same simulation run. That's the strange behavior that I don't understand.
