12 years ago --- Quote Start --- I am using Cyclone IV FPGA. Does it have the IO_PULLUP pin you mentioned? Also, how I control this IO_PULLUP pin? --- Quote End --- The Cyclone IV does not appear to have an IO_PULLUP control (the Stratix II has that pin). A search of pull-up in the Cyclone IV handbook yields the following statements: "The user I/O pins and dual-purpose I/O pins have weak pull-up resistors, which are always enabled (after POR) before and during configuration." and then a little later on "In user mode, the user I/O pins function as assigned in your design and no longer have weak pull-up resistors." So, the FPGA has weak pull-ups enabled when the device is not configured. If you want an external signal held low, then you'll have to use a pull-down. Cheers, Dave
