ATsao3
8 months agoState machine question in Arria X device
Hello all, In my design, there has a state machine having 28 states. The function is all good in RTL simulation. After full compilation and program to the device. There will be some state doesn't ...
sstrell
8 months agoNot sure what you mean by "4W_HEADER1(33 clk)" vs. "4W_HEADER1(1 clk)". I see a state "4W_HEADER1" but that's it.
Other than that, I'd try using parameter instead of localparam. I don't know if that affects the way Quartus "detects" state machines, but it's worth a try.
You should also break up those super deep else/if statements. Pull that logic out of the main next state logic and use case statements and intermediate signal(s) instead in separate processes. Are you having timing issues?
