15 years agostate machine file
i create a state machine using the state machine file (.smf) or editor, but i have a problem i have two states, but quartuss II doesnt acept more than one transition to the same state, and in my design i have two transition to the same state(state1) , and one transition to to the other state (state2), and the same in state2, two transitions to state 2 and one transition to state1.
I need help, this is the vhdl that generated the programm and also this is the diagram. -- Copyright (C) 1991-2009 Altera Corporation -- Your use of Altera Corporation's design tools, logic functions -- and other software and tools, and its AMPP partner logic -- functions, and any output files from any of the foregoing -- (including device programming or simulation files), and any -- associated documentation or information are expressly subject -- to the terms and conditions of the Altera Program License -- Subscription Agreement, Altera MegaCore Function License -- Agreement, or other applicable license agreement, including, -- without limitation, that your use is for the sole purpose of -- programming logic devices manufactured by Altera and sold by -- Altera or its authorized distributors. Please refer to the -- applicable agreement for further details. -- Generated by Quartus II Version 9.1 Build 222 10/21/2009 SJ Full Version -- Created on Tue Apr 27 18:06:02 2010 LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY states IS PORT ( clock : IN STD_LOGIC; reset : IN STD_LOGIC := '0'; sa : IN STD_LOGIC := '0'; sb : IN STD_LOGIC := '0'; v : OUT STD_LOGIC ); END states; ARCHITECTURE BEHAVIOR OF states IS TYPE type_fstate IS (state1,state2); SIGNAL fstate : type_fstate; SIGNAL reg_fstate : type_fstate; SIGNAL reg_v : STD_LOGIC := '0'; BEGIN PROCESS (clock,reg_fstate,reg_v) BEGIN IF (clock='1' AND clock'event) THEN fstate <= reg_fstate; v <= reg_v; END IF; END PROCESS; PROCESS (fstate,reset,sa,sb) BEGIN IF (reset='1') THEN reg_fstate <= state1; reg_v <= '0'; ELSE reg_v <= '0'; CASE fstate IS WHEN state1 => IF ((NOT((sa = '1')) AND NOT((sb = '1')))) THEN reg_fstate <= state2; ELSIF ((NOT((sa = '1')) AND (sb = '1'))) THEN reg_fstate <= state1; -- Inserting 'else' block to prevent latch inference ELSE reg_fstate <= state1; END IF; IF ((NOT((sa = '1')) AND NOT((sb = '1')))) THEN reg_v <= '1'; -- Inserting 'else' block to prevent latch inference ELSE reg_v <= '0'; END IF; WHEN state2 => IF (((sa = '1') AND (sb = '1'))) THEN reg_fstate <= state1; ELSIF ((NOT((sa = '1')) AND (sb = '1'))) THEN reg_fstate <= state2; -- Inserting 'else' block to prevent latch inference ELSE reg_fstate <= state2; END IF; IF ((NOT((sa = '1')) AND (sb = '1'))) THEN reg_v <= '1'; -- Inserting 'else' block to prevent latch inference ELSE reg_v <= '0'; END IF; WHEN OTHERS => reg_v <= 'X'; report "Reach undefined state"; END CASE; END IF; END PROCESS; END BEHAVIOR;
