11 years ago
Standard " Interface to User Logic" in Qsys Component Editor
I changed to Q13.0 from Q7.1 (also from Sopc to Qsys) just right now, then I are struggling many difficulties.
But the first thing is I need an "Interface to User Logic" to control some devices, which is "..\sopc\legacy components\interface to user logic".
I tried to build it in Qsys Component Editor, but I'm not sure if it's correct?
The attached pictures and codes are listed
You're very kind if can give any advice.
`timescale 1 ps / 1 ns
module bus32bits (
input clk, // clock.clk
input resetn, // reset.reset
input [9:0] address, // s0.address
input read, // .read
output reg [31:0] readdata, // .readdata
input write, // .write
input [31:0] writedata, // .writedata
input chipselect, // .chipselect
output [9:0] bus_add, // conduit_end.export
output bus_read, // .export
output bus_chipselect, // .export
input [31:0] bus_rd_data, // .export
output bus_write, // .export
output reg [31:0] bus_wr_data // .export
assign bus_write=write;
assign bus_read=read;
assign bus_add=address;
always@(posedge clk)
if(!resetn)
bus_wr_data<= 32'b0;
else
begin
bus_wr_data=(write&&chipselect)?writedata:32'hzz;
readdata=(read&&chipselect)?bus_rd_data:32'hzz;
end
endmodule
The interface should be like that.
component editor signal
