anonimcs
Contributor
2 years agoSplitting bidirectional vector into bits
Hi, As the title suggests, I'm trying to split the bidirectional vector into single bidirectional bits for my design. I have a dedicated IP (which I can't modify) and that one has a bit vector of ty...
- 2 years agoHi
you can't assign an inout port to a signal, but you can directly assign it in the component instantiation.
e.g.
generic_quad_spi_controller2_0_qspi_pins_data(0) => QSPI_IO1,
2_0_qspi_pins_data(1) => QSPI_IO2,
etc.
FvM
2 years agoHi
e.g.
etc.
e.g.
etc.
FvM
2 years agoOr use a concatenation on the right side
generic_quad_spi_controller2_0_qspi_pins_data => QSPI_IO4 & QSPI_IO3 & QSPI_IO2 & QSPI_IO1,
- anonimcs2 years ago
Contributor
I remember getting some errors before due to concatenating 2 signals (or a fixed value + a signal) at the component instantiation but they both look promising, thanks!
