Splitting bidirectional vector into bits
As the title suggests, I'm trying to split the bidirectional vector into single bidirectional bits for my design. I have a dedicated IP (which I can't modify) and that one has a bit vector of type inout for Quad SPI (the data for QuadSPI). And I want to communicate with a NOR Flash, but since Quad SPI has 4 data lanes, I wanted to split the inout vector coming from the IP and then assign my top level ports with those bits separately.
Do you know what's the most convenient way of doing it ? I tried adding two processes (given below) but I got the error " QSPI_IO1 directly or indirectly feeds itself". (and ofc the same for the other 3 data ports)
Thanks in advance !
entity myEntity is port ( CLK : in std_logic; QSPI_CLK : out std_logic; QSPI_CSN : out std_logic; QSPI_IO1 : inout std_logic; QSPI_IO2 : inout std_logic; QSPI_IO3 : inout std_logic; QSPI_IO4 : inout std_logic; ); end myEntity; architecture rtl of myEntity is signal qspi_data_vector : std_logic_vector(3 downto 0); -- 4-bit std_logic_vector component tx_soc is port ( clk_clk : in std_logic := 'X'; -- clk reset_reset_n : in std_logic := 'X'; -- reset_n generic_quad_spi_controller2_0_qspi_pins_dclk : out std_logic; -- qspi sclk generic_quad_spi_controller2_0_qspi_pins_ncs : out std_logic; -- qspi ss_n generic_quad_spi_controller2_0_qspi_pins_data : inout std_logic_vector(3 downto 0) := (others => 'X'); -- qspi data ); end component tx_soc; p_qspi_data_merge: process (QSPI_IO4, QSPI_IO3, QSPI_IO2, QSPI_IO1) begin -- Concatenate the QSPI port signals into qspi vector qspi_data_vector <= QSPI_IO4 & QSPI_IO3 & QSPI_IO2 & QSPI_IO1; end process; p_qspi_data_split: process (qspi_data_vector) begin -- Split the concatenated the QSPI port signals into single bits QSPI_IO1 <= qspi_data_vector(0); QSPI_IO2 <= qspi_data_vector(1); QSPI_IO3 <= qspi_data_vector(2); QSPI_IO4 <= qspi_data_vector(3); end process; soc_inst : component tx_soc port map ( clk_clk => core_clk, reset_reset_n => nios_reset_n, -- generic_quad_spi_controller2_0_qspi_pins_dclk => QSPI_CLK, generic_quad_spi_controller2_0_qspi_pins_ncs => QSPI_CSN, generic_quad_spi_controller2_0_qspi_pins_data => qspi_data_vector ); end;
- Hi
you can't assign an inout port to a signal, but you can directly assign it in the component instantiation.
e.g.
generic_quad_spi_controller2_0_qspi_pins_data(0) => QSPI_IO1,
2_0_qspi_pins_data(1) => QSPI_IO2,
etc.
- FvM
Hi
e.g.
etc.- FvM
Or use a concatenation on the right side
generic_quad_spi_controller2_0_qspi_pins_data => QSPI_IO4 & QSPI_IO3 & QSPI_IO2 & QSPI_IO1,- anonimcs
Contributor
I remember getting some errors before due to concatenating 2 signals (or a fixed value + a signal) at the component instantiation but they both look promising, thanks!
- ShengN_altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
