nicoh
3 years agoSPI (3 Wire Serial) without MISO
hi, it's possible to use the SPI (3 Wire Serial) IP CORE (Arria2) without connecting a signal to the MISO port? if so, should I connect it to a '1' default or '0'? thanks
RichardT_altera
3 years agoYou may refer to the user guide here:
You can tristate its miso output whenever its select signal is not asserted.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
