tnehowig
5 years agoSPI (3-Wire Serial) Intel FPGA IP sending 16 bits for every byte write
Hello, I'm having an issue with the SPI port sending out 16 clock cycles every time I try and write a single byte using a NIOS2f.
I've verified that the Data Register Width is set to 8 in Platfo...
- 5 years ago
Hi Tyler,
Glad you had solved the issue. Most of the time, it is always recommended to regenerate you IPs. The feature you said if you turn it on, it will automatically generates IP before compiling the design as it indirectly terminates the manual way where you generate in PD --> add new .qip --> and recompile.
SyafieqS
5 years agoHi Tyler,
