Speeding up Quartus P&R in the cloud
Oops.... I discovered that I didn't delete the setup folder where I extracted all the Quartus install files.... I'm trying out what effect removing that will have, hopefully I can get a docker image in the 10-20GByte size.
Other than that I rummaged through the Quartus install folders. I don't think I need the "nios2eds" folder in bold but there doesn't appear to be an installation option to exclude it, so I will try to delete them to see what happens.
/opt/intelFPGA_pro/19.3# du -hs * | sort -h
[deleted]
46M qsys
3.3G ip
3.7G nios2eds
7.6G quartus
/opt/intelFPGA_pro/19.3# cd quartus/
/opt/intelFPGA_pro/19.3/quartus# du -hs * | sort -h
[deleted]
47M sopc_builder
57M dspba
84M libraries
2.1G common
2.1G linux64
3.3G eda
/opt/intelFPGA_pro/19.3/quartus# cd common/
/opt/intelFPGA_pro/19.3/quartus/common# du -hs * | sort -h
[deleted]
2.0G devinfo
