10 years agoSource synchronous transmitter constraints
Hi all, before I start, I have read the Altera doc on this many times and often seem to end up confused one way or another though I have successfully constrained such interfaces before now. T...
10 years agoHello,
Should not you be using create_generated_clock in following way? create_generated_clock -name TX_CLK -source {surface_card_0|pll_tx_clk|altpll_component|auto_g enerated|pll1|clk[0]} [get_pins {div|q}] -divide_by 4 where instead of DIV you should mention your register name. Reference : https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_timequest_cookbook.pdf ( Figure 3, Example 3 ) Please share your view as I am also facing problem in giving constraints. Regards, Bhaumik
