Source Synchronous representation in TimeQuest - FPGA is a transmitter
Hi sstrell.
Yes, my .sdc file looks like that:
create_clock -period 8.0 -name fpga_clk [get_ports fpga_clk]
# Constrains PLL outputs. One output has 90 degree phase-shift for transmit clock
derive_pll_clocks
derive_clock_uncertainty
# Put a generated clock on output clock port to be referenced by set_output_delay constraints
create_generated_clock -source [get_pins {inst8|pll_1_inst|altera_pll_i|general[1].gpll~PLL_OUTPUT_COUNTER|divclk}] -name ssync_tx_clk_ext [get_ports {ssync_tx_clk}]
set_output_delay -clock ssync_tx_clk_ext -max 0.9 [get_ports {ssync_tx_data[*]}]
set_output_delay -clock ssync_tx_clk_ext -min -1.0 [get_ports {ssync_tx_data[*]}]
set_output_delay -clock ssync_tx_clk_ext -max 0.9 [get_ports {ssync_tx_data[*]}] -clock_fall -add_delay
set_output_delay -clock ssync_tx_clk_ext -min -1.0 [get_ports {ssync_tx_data[*]}] -clock_fall -add_delay
set_false_path -fall_from [get_clocks {inst8|pll_1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}] -rise_to [get_clocks ssync_tx_clk_ext] -setup
set_false_path -rise_from [get_clocks {inst8|pll_1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}] -fall_to [get_clocks ssync_tx_clk_ext] -setup
set_false_path -fall_from [get_clocks {inst8|pll_1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}] -fall_to [get_clocks ssync_tx_clk_ext] -hold
set_false_path -rise_from [get_clocks {inst8|pll_1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}] -rise_to [get_clocks ssync_tx_clk_ext] -hold
set_false_path -to [get_ports {ssync_tx_clk}]
So I can confirm that my constraints are like you suggested.
Ivan
