15 years agoWOW thanks for such a quick response !
This has, and still is, a very steep learning curve, but here's what i've found. I set the constraints as you said, as follows 1)# the clock input to the device create_clock -name src_clk -period 125MHz [get_ports src_clk] 2)# the clock output (inversion of input) create_generated_clock -name inv_src_clk_out -invert -source [get_ports src_clk] 3)# set relationship between the clock going out and the data going out set_output_delay -min 0.0 -clock [get_clocks inv_src_clk_out] [get_ports data_out] set_output_delay -max 0.0 -clock [get_clocks inv_src_clk_out] [get_ports data_out] which didn't meet timing and produced the following (i've attached a txt version of this post as I couldn't get the diagram to display properly) ______ launch __| |_______ : _______ latch _________| : : : data arriv _________:_____:_______ _______________X________ : : : : : : data reqd _________:_____:__ _________X_____:___ : : : : Relationship 4ns Clock Delay : 3.249 Data Delay : 3.229 Data Arrival : 6.478 Data Reqd : 4 some clock uncertainty Slack : -2.498 One thing i'm not sure about is that this 'model' does not take into account the delay of the clock through the ALTDDIO cell which i've checked as being 5.075 ns (report -from src_clk -to inv_src_clk_out -through altddio cell) Questions: 1) what happened to using virtual clocks ? 2) would i be correct in assuming that if this delay is added to the relationship somehow, this would then shift the latch clock to the right by 5.075 ns giving me a new setup of 2.557 ns and meeting timing 3) do my set_output_delay commands need modifying as i'm not 100% sure i understand what they are doing. TIA Johnnyman
