8 years agoSource-Synchoronous Interface: Edge Aligned SDR Clock constraint
Hi. Iam designing using a Cypress FX3 device (CYUSB3014-BZXC) and a Cyclone IV FPGA(EP4CE115F29C8). The FPGA has a external 50 MHz oscillator. The design shouldrun @ 100 MHz. To do this I have...
8 years agoHi Strell,
Thank you for you review. The issue that I have, is related to the clock relationship. As the internal register are clocked by the internal 100MHz and the external device is a clocked by a 180° 100 MHz offset, the design has a setup relationship of 5 ns instead or original 10 ns for the output and input register connected to the output/input pin. I attached a figure for this violation. https://alteraforum.com/forum/attachment.php?attachmentid=15430&stc=1 For instante, the FX3_flaga, FX3_flaga, FX3_flaga, FX3_flaga are signals cominf from the external device.always @(posedge clk_100, negedge reset_)begin
if(!reset_)begin
flaga_d <= 1'd0;
flagb_d <= 1'd0;
flagc_d <= 1'd0;
flagd_d <= 1'd0;
end else begin
flaga_d <= FX3_flaga;
flagb_d <= FX3_flagb;
flagc_d <= FX3_flagc;
flagd_d <= FX3_flagd;
end
end The register connected to the FX3_flagx to flaga_x has a setup relationship of 5 ns. Which is the right way to constraint this? a set_multicycle_path between them? or a set_false_path directive?
