14 years ago
SOPC VIP throughput problem
hello,
I'm setting up a SOPC system using the VIP IP modules and now I'm bumping into a problem.
The VIP system is mixing two streams into a single 800x600 stream which is clocked out with a 75Hz framerate to screen,
One stream is a 640x480 video input stream from camera:
cvi (640x480) -> framebuffer -> mixer (din_1)
while the other is :
framereader (800x600) -> mixer (din_0, background layer)
However, the output to screen is displaying a single color (this color seems to be dark green) with a black frame on the left side of the screen.
Now, if I change either the first or the second stream, replacing with a testpattern generator, I'm able to display the video output to screen, but when I mix the two original streams, there is something going wrong.
I tried increasing the pixel FIFO size of the clocked video output module to 5000 pixels, but this did not help.
Can anyone tell why this i s happening ?
