15 years agoSOPC Simulation with ModelSim Altera vs. ModelSim PE
I have generated an SOPC system and would like to simulate using ModelSim PE rather than ModelSim Altera but am running into some issues (Note: I have both versions installed and they are both properly licensed...):
1. Under Tools -> Options -> HDL Simulator Option, I only See ModelSim Altera. What if I want to use ModelSim PE? Why is this option not available? 2. In Quartus I have selected ModelSim PE as my simulator under options -> EDA tool. I thought that this would have made the PE version available once I launch SOPC. However this is not the case. 3. If I open up ModelSim Altera and run a simulation for a SOPC-generated system, the setup_sim.do file executes fine. However, if I follow the same process with ModelSim PE, I get an error when executing setup_sim.do at line 39. Why does PE not understand this file? Has anyone run into this issue before?
