15 years ago
SOPC builder erroro on quartus 10.0 - windows7
Hi all
I have a problem whlile using quartus2 web edition 10.0 and SOPCbuilder in Windows7 (64bit).
Adding the CVI appears a set of errors, like
--- Quote Start ---
Error: set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 to retain temp files
Error: Command: c:/altera/10.0/quartus//bin/quartus_sh.exe -t C:/Users/hp/AppData/Local/Temp/alt4824_8295765401181654092.dir/0002_sopcqmap/not_a_project_setup.tcl
Error: Command: c:/altera/10.0/quartus//bin/quartus_map.exe not_a_project --generate_hdl_interface=C:/altera/10.0/ip/altera/clocked_video_input/src_hdl/alt_vipcti100_Vid2IS.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/hp/AppData/Local/Temp/alt4824_8295765401181654092.dir/0002_sopcqmap/
--- Quote End ---
I've set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 as environment variable but still i don't get any result.
Could anybody help me please?
    are you running Quartus as admin? this seems to be an issue with the VIP Suite (check MegaCore errata)
    Hello
    thanks for your reply.
    Yes, I ran it as admin, but still I had the same problem.
    I noticed it happens only when I use CVI or CVO from VIP, other megafunctions does not seem to be affected (but I did no try to generate the sopc file).
    Is there any possible solution or workaround?
    at first, thought it is due to the 64 bit system instead of using a 32.
    I am working on video data paths so I need to use VIP suite.
    Maybe I should install quartus 9.1 sp2 instead quartus 2 10.0? or virtualizing on another OS?
    Any hint would be precious.
    Thanks for your help
    Best Regards
    Phate.
    is it when you actually add the CVI or CVO to the SOPC system, or during generation?
    i'm not seeing that here on a Win7-64 machine, QII 10.0 Subscription Edition
    next thing to suspect is an installation issue maybe?
    Well done, it's my fault.
    I didn't think that the error was related only to the CVI/CVO, i thought that was an SOPC builder generic error.
    Today I'll install STRATIX device support and I'll see if the bugs disappear.
    I'am a little bit sorry that I have to install stratix support in order to use some of the VIP ips on other devices...
    Thanks a lot everyone for your help and hints, I'll let you know.
    Best regards
    Phate.
    --- Quote Start ---
    Perhaps you need to install Stratix II support (even if you aren't using Stratix II) as discussed in some other recent threads (http://www.alteraforum.com/forum/showthread.php?t=24376)?
    --- Quote End ---
    good thinking, i expected an error mentioning STRATIX but that's probably below the first one which matches the screen shot from your link
    Hey, I run on Ubuntu 10.10.
    I use the paid quartus II toolchain 10.1sp1.
    I installed all devices.
    I installed quartus, nios-ide and modelsim
    Thats my sopc builder prob:
    Error: Command: /opt/altera/10.1/quartus/bin/quartus_sh -t /tmp/alt5070_6587957599808173728.dir/0006_sopcqmap/not_a_project_setup.tcl
    Error: Command: /opt/altera/10.1/quartus/bin/quartus_map not_a_project --generate_hdl_interface=/home/walther/canrouter/lib/wrapper/avalon/avalon_tiss.vhd --set=HDL_INTERFACE_OUTPUT_PATH=/tmp/alt5070_6587957599808173728.dir/0006_sopcqmap/
    Error: export: 137: 2000.00: bad variable name
    Error: Command took 0.039s
    I also run locale-gen de and locale-gen en...
    What can I do? I am really desperate.
