15 years ago
SOPC Builder Error: add old 'class.ptf' based component (and solution to fix it)
Tool: SOPC Builder 9.1, SP2
Action:
In SOPC Builer, after you add old 'class.ptf' based component (maybe from:
C:\altera\91\ip\altera\sopc_builder_ip\) and then press 'Generate',
you may get error as follows:
Error: One or more components could not be located (MODULE_NAME)
SOLUTION
First, exit SOPC Builer with 'Save' changes. Then open text file located in:
/YOUR_PROJECT_DIR/.sopc_builder/install.ptf
You can find many WRONG paths as following example:
local = "c:/altera/91/quartus//../ip/altera/nios2_ip/altera_nios2";
Delete text 'quartus//../' in each 'local' parameter, then save this file.
Re-run SOPC Builder and generate the system.
At first I think this issue is introduced by text '//',
but thanks to akira's post:
http://www.alteraforum.com/forum/showthread.php?t=24959
it seems OK for text '//'.
Same condition can be found in: /altera/91/ip/.sopc_builder/install.ptf
BUT it DOESN'T make problem... (why???)
Hope this post is helpful.
1 Reply
    My error msg was different :
    ISP1362:avalon_slave_1_irq:"associated addressable interface"(assocaitedAddressablePoint) out of range..
    could you pl tell me if anything can be done,
    i got this error when i tried to update older sopc .ptf file to .sopc file,
