BChri3
8 years agoSome MegaWizard functions fail to generate under Ubuntu/Linux.
When trying to create a LPDDR2 (or any memory) interface, PLL, RS232, or PS/2 Controller, the MegaWizrd gets an error and then ends with a "Generation FAILED" message. This problem does not exist ...
BChri3
8 years agoI believe that thread you suggested did the trick. As per the post on "July 27, 2017 at 4:33AM", I "removed" the libccl_curl_drl.so file located in my .../18.0/quartus/linux64 directory and now VHDL IP generation seems to work without errors. I thought I searched the forums for the "ld.so: dl-close.c" error but I missed that post somehow.
Again, thank you for your time and help...I appreciate it.
