15 years agoAs I already it's most likely not an error. SignalTap's representation is hardware related. If you display a bit-vector register, but some bits aren't actually existing as register bits, they aren't recorded and not filled in when displaying the values.
Your observation, that the design output changes, when the "missing bits" are exposed as outputs, needs further explanation. If these bits are unequivocally processed for the final design output, they won't be discarded. There must be something special with your design.
