11 years agoI've been studying the code for this exercise, but I erorr
code; library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity counter is generic ( n : integer := 4; k : integer := 8 ); port ( clock : in STD_LOGIC; reset_n : in STD_LOGIC; Q : out STD_LOGIC_VECTOR(n-1 downto 0); SW: in std_logic_vector(7 downto 0); KEY : in std_logic_vector(1 downto 0); LEDR : out std_logic_vector(7 downto 0) ); end counter; architecture rtl of counter is signal Q_int: std_logic_vector(n-1 downto 0); begin PROCESS(clock, reset_n) begin if (reset_n = '0') then Q_int<= (others => '0'); elsif ((clock'event) and (clock = '1')) then if Q_int>= k-1 then Q_int<= (others => '0'); else Q_int <= Q_int + 1; end if; end if; end process; Q <= Q_int; end rtl; architecture Behavioral of counter is component counter generic ( n : integer := 4; k : integer := 8 ); end component; begin eight_bit: counter generic map ( n => 8, k => 4) port map eight_bit( clock, reset_n, Q, KEY(1), KEY(0), LEDR ); end Behavioral;
