8 years agosof2flash output different than quartus_cpf
Hi everybody,
I try to convert my project sof file into an srec file to store it into a CFI memory. On my board, I have a PFL onto a Max device to boot the bitstream from CFI memory address 0x01F0_0000. 1: memory file generation with quartus_cpf I use the "Convert Programming File" tool to create a "cof" file, which will help me to create a "pof" file to download into the memory. The "cof" file is describded below :<?xml version="1.0" encoding="US-ASCII" standalone="yes"?><cof>
<eprom_name>CFI_1GB</eprom_name>
<output_filename>bitstream.pof</output_filename>
<n_pages>1</n_pages>
<width>1</width>
<mode>0</mode>
<sof_data>
<start_address>01F10000</start_address>
<user_name>Page_0</user_name>
<page_flags>1</page_flags>
<bit0>
<sof_filename>bitstream.sof</sof_filename>
</bit0>
</sof_data>
<version>5</version>
<create_cvp_file>0</create_cvp_file>
<options>
<map_file>1</map_file>
<option_start_address>1f00000</option_start_address>
<dynamic_compression>0</dynamic_compression>
</options>
</cof> I create the pof file with the command : quartus_cpf -c bitstream.cof I download this "bitstream.pof" file into the memory using Quartus Programmer. Then, the FPGA boots fine at board power up ! 2: memory file generation with sof2flash Let's say the FPGA is already running and a Nios2 is running on it. I can then use the nios2-flash-programmer to overwrite the flash contents. I create the srec file with the following commands : sof2flash --input=bitstream.sof --offset=0x1F10000 --output=bitstream.flash --pfl --programmingmode=PS --optionbit=0x1F00000 It creates two files : bitstream.flash and bitstream.map.flash. I download these two files into the memory with the following command : nios2-flash-programmer --base=0x0 -g bitstream.map.flash bitstream.flash
Then, the FPGA doesn't start and CONF_DONE is stuck at '0' at power up ! 3: differences :
I have dumped the memory for both configuration. There is only one difference located after the option area: (option area is the four first lines, the difference is in the fifth one) quartus_cpf configuration :
S32501F00000101FE41FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3
S32501F00020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9
S32501F00040FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9
S32501F00060FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9
S32501F0008003FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85
sof2flash configuration :S32501F00000101FE41FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3
S32501F00080FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89
I cannot explain this. Does anyone have a clue ? I'm using Quartus 12.1sp1. Thanks1 Reply
I've manage to create my srec file by using quartus_cpf with a cof file to create a pof (as in solution n°1 in my post). Then convert back the pof file into ihex also with quartus_cpf and then into an srec with nios2-elf-objcopy.
I have checked and the byte 0x03 is still there and every thing works fine. It's still a strange behavior and I'd like to know if this is a 12.1sp1 bug.quartus_cpf -c bitstream.pof bitstream.hexout mv bitstream.hexout bitstream.hex nios2-elf-objcopy -I ihex -O srec bitstream.hex bitstream.flash
