8 years agosof2flash output different than quartus_cpf
Hi everybody, I try to convert my project sof file into an srec file to store it into a CFI memory. On my board, I have a PFL onto a Max device to boot the bitstream from CFI memory address 0x...
8 years agoI've manage to create my srec file by using quartus_cpf with a cof file to create a pof (as in solution n°1 in my post). Then convert back the pof file into ihex also with quartus_cpf and then into an srec with nios2-elf-objcopy.
quartus_cpf -c bitstream.pof bitstream.hexout
mv bitstream.hexout bitstream.hex
nios2-elf-objcopy -I ihex -O srec bitstream.hex bitstream.flash I have checked and the byte 0x03 is still there and every thing works fine. It's still a strange behavior and I'd like to know if this is a 12.1sp1 bug.
