--- Quote Start ---
Hello
You can find the information you are requiring in the CycloneIII Handbook
Chapter
11. seu mitigation in the cyclone iii
device family 1 - Quartus adds a 32bit pre-calculated CRC value at the end of sof file. This file is located to your project directory.
Also, a 16bit CRC is added in each CRAM frame.
2 - You are not able to recompute the checksum.This is automatic calculated by the Hard logic circuit in the fpga.
3 - I think that you can read the 32bit CRC register via your jtag interface
Thank you
Dimitrios Agiakatsikas
--- Quote End ---
how about rbf ?
how can i figure out what is the data mean in the rbf file ?
