17 years ago --- Quote Start --- One other thought is to add the Tcl script as a button to the GUI. It's pretty easy. Tools -> Customize -> Toolbars and add the Tcl toolbar. Then Tools -> Tcl and you can link a Tcl button to a particular script. Still a manual step at the end, but not too bad. --- Quote End --- To give you an idea of what I am using this for, I have the tcl script look for a node in the post-fitting system to see which out of two VHDL files was compiled. The advantages of this are: - I can share all Quartus settings, timing constraints and SOPC files - I won't have to duplicate all of the above and keep them in sync - HDL designer, which I am using to produce the VHDL, is the only place I need to deal with which configuration I am building - there is no risk of people thinking a .sof file was built from one design while it was really built from another I'll consider the button if I cannot find another solution and people really want to use smart compilation. Thanks for the suggestion.
