17 years ago --- Quote Start --- Hi All, In Quartus II, the classic timing analysis report shows: Slack:Not operational: Clock Skew>Data Delay, but,when i download the whole design to the fpga, it can works without any error. meanwhile, when i right-click the red information in the report and chose "locate in RTL viewer" , could see the two register use two different clock, which is right a part of the design. i don't think this situation should be analyzed with the regulation of "clock hold analysis" ,for the two register use different clock. but how should i deal with the error information (with red color) in the classic timing analysis report? Thank you! --- Quote End --- Hi, that means you have a clock domain crossing here. Connecting the register simply together will not work in all cases. There is a lot of stuff in the forum regarding clock domain crossing. Kind regards GPK Gerd
