10 years agosine wave using Different duty cycles of PWM
Hi i am having problem in generating different duty cycles of PWM. can somebody check my code and tell what is wrong. well code is generating a duty cycle but it does not change it automatically as t...
10 years agoI use quartus and you have to set it in pin assignments not in the code. you can download the file from internet be sure it is in csv format.
