17 years agoIf you have a sinewave described with N bits (all positive values as you say) the MSB (most significant bit) of your sinewave will be your clock signal.
Cheers ODIf you have a sinewave described with N bits (all positive values as you say) the MSB (most significant bit) of your sinewave will be your clock signal.
Cheers OD
