17 years agoyes, but I thought I would be able to do the following:
when sinewave > fpga threashold , fpga will output 1. when sinewave < fpga threashold , fpga will output 0. so if I use a sinewave with a minimum value = 0, that is a normal sinewave with a positive offset, the fpga will act as if its cutting the upper and lower edges of the sinewave and outputs a clock.. isnt that right?
