19 years ago --- Quote Start --- If your node is a register, make the following assignments: 1. Preserve register 2. Add to simulation waveform For the second assignment to work you must have "Automatically add pins to simulation waveforms" turned on in the settings dialog for the Simulator. --- Quote End --- I searched in Quartus Help for a while for "preserve" and changed the settings in the Assignmend Editor like this: http://img527.imageshack.us/img527/6268/simuregisterspk0.gif (http://img527.imageshack.us/img527/6268/simuregisterspk0.gif) But it doesn't help. The warnings stay the same and the nodes can't be find in a different filter than "Design Entry". The "Automatically add pins to simulation waveforms" allready was turned on, so I don't had to change this. bye
