19 years ago --- Quote Start --- I inserted the signalname in the *.wvf with the Node Finder, therefore the signal should be in the design, and I'm very sure that the "io_in_syn[6]" IS in the VHDL-Code. --- Quote End --- I wonder whether you used the appropriate filter in the Node Finder. "Design Entry (all names)" works for most things I do, but sometimes I have to use another filter. Is the node name you're having trouble with listed by the "Post-synthesis" filter for functional simulation or by the "Post-Compilation" filter for post-fit simulation? I have seen even register names be different post-synthesis versus post-fit.
