18 years agoSimulator assignments
I try to simulate a design with the QuartusII simulator. Some of the signals are however synthesised away. I connect the signals to output pins and use the "Implement as Output of Logic Cell", "Add to Simulation Output Waveforms" and "Preserve Fan-out Free Register Node". Does the signal have to be available at top-level in order to preserve the signal during simulation? It is test-signals on lower-level blocks, so I dont want to append the signal to the top-level. Hope someone can help. Regards, Morten
