14 years ago
Simulation using ModelSim
Hi..
i am simulating a project using modelsim i am facing some problems
1. i have written a test bench for my simulation and assigning some data at input port witch is 8bit wide and suppose to receive packet of data which is 53bytes long
2. when i am trying to input a data it is accepting only one byte at a time
3.how to input a data which is a packet of 53bytes to my input port.
please help me
thank you
    well post some code and your testbench and we'll see.
    With a testbench you can do a load of stuff you cannot do in synthesisable VHDL, so its very easy to control data flow.
    Dear sir here is the code for test bench....
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    USE ieee.std_logic_arith.ALL;
    USE ieee.std_logic_unsigned.ALL;
    LIBRARY lpm;
    USE lpm.lpm_components.ALL;
    LIBRARY work;--(i added this library)
    USE work.voq_input_package.ALL;
    entity voq_switch_tb is
    end voq_switch_tb;
    architecture tb of voq_switch_tb is
    component voq_switch is
    PORT (
    fp1 : IN STD_LOGIC; --input frame pulse lines
    fp2 : IN STD_LOGIC;
    fp3 : IN STD_LOGIC;
    fp4 : IN STD_LOGIC;
    data_in1 : IN BYTE; --input data byte lines
    data_in2 : IN BYTE;
    data_in3 : IN BYTE;
    data_in4 : IN BYTE;
    global_reset : IN STD_LOGIC; --Resets all the counters,registers and the buffer
    reset : IN STD_LOGIC; --Resets everything but the buffer
    clock : IN STD_LOGIC;
    fp_out_port1 : OUT STD_LOGIC; --output frame pulse lines-
    fp_out_port2 : OUT STD_LOGIC;
    fp_out_port3 : OUT STD_LOGIC;
    fp_out_port4 : OUT STD_LOGIC;
    data_out_port1 : OUT BYTE; --output data_lines
    data_out_port2 : OUT BYTE;
    data_out_port3 : OUT BYTE;
    data_out_port4 : OUT BYTE;
    data_valid1 : OUT STD_LOGIC; --output data_valid lines
    data_valid2 : OUT STD_LOGIC;
    data_valid3 : OUT STD_LOGIC;
    data_valid4 : OUT STD_LOGIC;
    --Source port number
    incoming_port_to_output1 : OUT STD_LOGIC_VECTOR (2
    DOWNTO 0);
    incoming_port_to_output2 : OUT STD_LOGIC_VECTOR (2
    DOWNTO 0);
    incoming_port_to_output3 : OUT STD_LOGIC_VECTOR (2
    DOWNTO 0);
    incoming_port_to_output4 : OUT STD_LOGIC_VECTOR (2
    DOWNTO 0);
    --Priority vector output for simulation purpose
    P : OUT STD_LOGIC_VECTOR (7 DOWNTO 1);
    --request to scheduler and grant coming from scheduler for simulation
    request : OUT STD_LOGIC_VECTOR(16 DOWNTO 1);
    grant : OUT STD_LOGIC_VECTOR(16 DOWNTO 1)
    end component;
    signal fp1: STD_LOGIC:='0';
    signal fp2: STD_LOGIC:='0';
    signal fp3: STD_LOGIC:='0';
    signal fp4: STD_LOGIC:='0';
    signal data_in1,data_in2,data_in3,data_in4: BYTE:="00000000";
    signal global_reset: STD_LOGIC:='0';
    signal reset : STD_LOGIC:='0'; --Resets everything but the buffer
    signal clock : STD_LOGIC:='1';
    signal fp_out_port1 : STD_LOGIC:='0'; --output frame pulse lines-
    signal fp_out_port2 : STD_LOGIC:='0';
    signal fp_out_port3 : STD_LOGIC:='0';
    signal fp_out_port4 : STD_LOGIC:='0';
    signal data_out_port1 : BYTE:="00000000"; --output data_lines
    signal data_out_port2 : BYTE:="00000000";
    signal data_out_port3 : BYTE:="00000000";
    signal data_out_port4 : BYTE:="00000000";
    signal data_valid1 : STD_LOGIC:='0'; --output data_valid lines
    signal data_valid2 : STD_LOGIC:='0';
    signal data_valid3 : STD_LOGIC:='0';
    signal data_valid4 : STD_LOGIC:='0';
    signal incoming_port_to_output1 : STD_LOGIC_VECTOR (2 DOWNTO 0);
    signal incoming_port_to_output2 : STD_LOGIC_VECTOR (2 DOWNTO 0);
    signal incoming_port_to_output3 : STD_LOGIC_VECTOR (2 DOWNTO 0);
    signal incoming_port_to_output4 : STD_LOGIC_VECTOR (2 DOWNTO 0);
    signal P : STD_LOGIC_VECTOR (7 DOWNTO 1);
    signal request : STD_LOGIC_VECTOR(16 DOWNTO 1);
    signal grant : STD_LOGIC_VECTOR(16 DOWNTO 1);
    constant num_cycles : integer := 320;
    begin
    U_voq_switch:voq_switch port map(
    fp1,fp2,fp3,fp4,
    data_in1,data_in2,data_in3,data_in4,
    global_reset,
    reset,
    clock,
    fp_out_port1,fp_out_port2,fp_out_port3,fp_out_port4,
    data_out_port1,data_out_port2,data_out_port3,data_out_port4,
    data_valid1,data_valid2,data_valid3,data_valid4,
    incoming_port_to_output1,incoming_port_to_output2,incoming_port_to_output3, incoming_port_to_output4,
    P,
    request,
    grant
    -- architecture declarative part
    -- constant num_cycles : integer := 320;
    --signal clock : std_ulogic := '1';
    -- architecture statement part
    process
    begin
    --for i in 1 to num_cycles loop
    for i in 1 to 100 loop
    clock <= not clock;
    wait for 10 ns;
    clock <= not clock;
    wait for 10 ns;
    -- clock period = 10 ns
    end loop;
    wait; -- simulation stops here
    end process;
    -- concurrent process to offer clock signal
    --process
    --begin
    --clock <= '0';
    -- wait for 5 ns;
    -- clock <= '1';
    --wait for 5 ns;
    -- end process;
    process
    variable err_cnt:integer:=0;
    begin
    -- case 1
    fp1 <= '1';
    wait for 20 ns;
    fp1<='0';
    wait for 10 ns;
    data_in1 <= "00000110";
    wait for 20 ns;
    data_in1 <= "00000111";
    wait for 20 ns;
    data_in1 <= "00001000";
    wait for 20 ns;
    data_in1 <= "00001001";
    wait for 20 ns;
    data_in1 <= "00001010";
    wait for 20 ns;
    data_in1 <= "00111010";
    -- assert (data_out_port1="11111111") report "Sum Error!" severity error;
    --assert (carry='0') report "Carry Error!" severity error;
    -- if (data_out_port1/="01010101" ) then
    -- err_cnt:=err_cnt+1;
    -- end if;
    -- summary of testbench
    if (err_cnt=0) then
    assert false
    report "Testbench of Adder completed successfully!"
    severity note;
    else
    assert true
    report "Something wrong, try again"
    severity error;
    end if;
    wait;
    end process;
    end TB;
    configuration CFG_TB of voq_switch_tb is
    for TB
    end for;
    end CFG_TB;
    you need to add more data to the second process. I also suggest making it sensitive to clock rather than waiting for time periods between inputs.
