16 years agoModelSim-Altera Starter Edition is a free alternative, but you will need to learn a bit about an HDL to put it all together. what you can do is convert your .vwf into a Verilog or VHDL test bench, and also convert any .bdf files into HDL files, and then you can use ModelSim-ASE. for a beginner using the NativeLink simulation support can be helpful:
http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
