lrobe12
6 years agoSimulation Runtime Error
Hi there , I'm extremely new to Quartus hence this probably rookie problem.
Basically upon trying to simulate my basic circuit with ModelSim I have an error which is attached below.I have checked the vhdl code and all seems fine ( line 12 of the vhdl would be line 39 as all above are comments).
Any help would be great.
1 Reply
- SyafieqS
Hi Lauren,
Assuming you have done the compilation
- Go to your project, select your hdl and testbench, then click simulate on the window option.
- A start simulation window will pop out
- In the library (for you gate_work i guess) select your testbench and hdl file, right click and click simulate.
- A window simulation will pop up. select your desired signal in the object window, select them and add wave (depend on what signal you want to simulate)
- Click run on the window option to run the simulation.
