15 years ago
Simulation in ModelSim Altera Starter Edition
Hi guys,
need a little bit help. I try ModelSim ALTERA STARTER EDITION 6.5b for the first time, have created a test project (two inputs, two outputs) and wanted to simulate it. My problem is – I can add my signals to the wave window, but I did not find a way to add a waveform to my signals in this window. I have used ModelSim SE PLUS before and in this program if I clicked with the right mouse button in the Objects window, I have got in the pull-up menu (upon other items) the “create wave” item. In the ModelSim Altera Starter Edition I see all these items too, except the “create wave” item. How can I add a waveform here?
Thank you
    You cannot compile test benches with quartus. Quartus only understands the "wait until" command for synthesising code. Test benches cannot be synthesised.
    Secondly, do not use std_logic_arith and numeric_std in the same file.
    Tricky, thanks for your information about Quartus.
    You are right, it is not a good idea to use std_logic_arith and numeric_std together (have overlooked it as I copied parts of two different designs)
    --- Quote Start ---
    no, i don't think so
    try Quartus II 10.1 and ModelSim 6.6c
    --- Quote End ---
    Hello, I continue with this topic while my question is the same.
    How can I use the waveforme editor with modelsim 6.6d ? I've tryed with the example (counter.v) but I cannot change the waves.
    Hello all,
    I am new to this software and trying to learn in my free time.
    Can anyone tell me how to setup modelsim on Quartus -II? I have tried to follow the steps from the pdf file provided,but I cannot see the option of settings in bold under Assignment.
    Is there any way I can open Modesim once I download Quartus-II?
