11 years agoThanks Dave.
I've now got the simulation working in ModelSim-Altera with a top level VHDL project. I started with a blank project and followed the guidelines in the " Simulating Designs with Lower-Level Qsys Systems" document. My new project has shorter folder names than the example provided. I suspect it may be an issue with a file/path buffer overrun somewhere. I found an older thread which had a similar problem: http://www.alteraforum.com/forum/showthread.php?t=37564 (http://www.alteraforum.com/forum/showthread.php?t=37564) Although the VHDL simulation is running in ModelSim-Altera, the transcript gives a performance warning: # Loading Qsys_inst_reset_bfm.altera_avalon_reset_source(behavioral) # ** Warning: Design size of 141 instances exceeds ModelSim ALTERA recommended capacity. # This may because you are loading cell libraries which are not recommended with # the ModelSim Altera version. Expect performance to be adversely affected. B_T
