eman_delete
3 years agosimulating a desing with DDR3
Hello, I have the Quartus+Qsys design which can be simulated with vcs. This design does have a DDR3 controller in the NIOS block. The design has been never simulated with the DDR3 simulation model. ...
AdzimZM_Altera
3 years agoHello,
I'm Adzim will assist you on this thread.
To generate the DDR3 simulation model, you can get it by generating the DDR3 Example Design from Quartus.
Then you can take the memory model and connect it to your memory controller.
The connection can follow from the Example Design.
This is a reference document for Arria 10 device. Link: https://www.intel.com/content/www/us/en/docs/programmable/683842/21-1-19-2-0/design-example-quick-start-guide-for.html
Adzim
