16 years agosimulate not top level entity
hello,
I'm a beginner in quartus i have create a project with tow entity in tow different file .vhd then i set the first entity, witch has the same name of the project, as a top level entity. now the problem is when i would simulate the second entity(not the top level entity) i dont found pins of this entity in the list of signals given by the NODE FINDER. why? and how i can simulate this entity if her pins are not found in the list? to simulate an entity, is it necessary to create a new project with only one file and set it a top level etity? i use Quartus II Web Edition 9.1 thanks a lot.
