Altera_ForumHonored Contributor16 years agosimulate not top level entity hello, I'm a beginner in quartus i have create a project with tow entity in tow different file .vhd then i set the first entity, witch has the same name of the project, as a top level entity. ...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
