11 years ago
Simple testbench_for_loop - Question
I am using a simple test bench, as attached.
Please refer to the for loop portion of the test bench, When I run a simulation using this test bench, I except the
address to run till 1250 and then stop..but the address keeps on incrementing even after 1250..
How do I write the for loop in testbench, to make the address count from 0 to 1250, and once reaching 1250..it should reset and count again.
Please advice.
Manoj
    because after the loop, the process resets and does the loop again. incrementing the address forever
    You need a wait after the loop.
