17 years agoSimple block diagram problem
I have begun to use quartus II (7.2) and im very new to it, and so im assuming if you take a look at my block diagram you will see the problam straight away.I created a simple block diagram that implements a truth table.
Basically when i compile my project, i get a bunch of errors of this sort: --- Quote Start --- Error: Port "INI1" of type AND3 of instance "inst1" is missing source signal --- Quote End --- I have uploaded a picture of the block diagram, and a zipped project folder.. I think i know what the problem may be myself, but have no soloution... In the block diagram all my connections have an 'X' marker...i recall using quartus block editor befor and not seeing those, at that my stuff would compile...But i cant draw connections without that 'X' mark now.
