18 years ago
SignalTapII doesn't trigger anything!!!
I'm a beginner in using QuartusII and i've got a problem with SignalTapII Analyzer. I create my SignalTap file, configure it and launch it. But during the analysis, nothing is trigerred!!
I've used simple triggers, directly connected to switches on the board, but nothing happened. However, when i stop analysis i see the correct position of my switches... So it seems i've probe the correct signals.
I've read altera's tutorial and book on SignalTap, but it didn't solve my problem. Moreover i tried different kind of compilations (incremental, classic). For each type i've defined triggers in post-fit/pre-synthesis list, in order to see if my problem is related to compilation.
I really don't understand where's the problem,
If anyone has an idea he's really welcome!
Thank you,
Yann.
    Hello Dan,
    under this circumstances, I would expect the signal to trigger SignalTap. You should contact support and report the problem. Do you get timing errors related to SignalTap acquisition?
    I didn't yet experience dubious behaviour with V7.2 SignalTap, I get sligthly annoyed at the changes to segmented acquisition mode. But no doubt, there have been fundamental changes, may be something went wrong with trigger processing.
    Frank
