18 years agoI've had the same problem with 7.2. The signal tap would trigger on one condition, but not another. Both occurred and you could see both events in the display, but only one would actually trigger the capture. This used to never be a problem, so I must assume that this is a new "feature" that Altera has graciously included. I just loaded SP1, so I'll see if this is fixed in this SP.
The work around seems to be to pick a working trigger or just not use signaltap for that specific condition. Regards, Dan
