18 years agoHello,
I'm not sure what you mean with "only one trigger"? Quartus Signaltap has multiple trigger levels, in Basic trigger mode, the trigger condition for each level is a logical AND of all active node related condtions. If you select individual conditions, that won't occur in a combination, you get no trigger, as I already mentioned. SignalTap Operation is documented detailed in Quartus II Handbook. Regards, Frank
