13 years ago
SignalTap working on Windows but not on Linux
Hi!
I'm having some problems when trying to use SignalTap on Linux.
I'm using two different setups:
- DE2 development board with integrated USB Blaster
- Custom board (EP4CE15) + external USB blaster clone
The thing is, on Windows I can use SignalTap on both setups with no problem.
On Linux I can use SignalTap with the DE2 but not on my custom board. Programmer works OK though. As far as I know it's only SignalTap what it's not working.
Do you know what could the problem be? Anything I can try?
Thank you very much for your help!
Information that can be useful:
- Linux Quartus II 64-Bit Version 13.0 Build 156. I tested also 12.1sp1 with same behaviour.
- Tested on Ubuntu 12.04 and 13.04 64 bits
"lsusb -v" for DE2 and USB blaster clone differ slightly on bMaxPacketSize0 and some names and serial numbers. I don't know if that could be a problem
DE2 USB Blaster
$ sudo lsusb -v -d 09fb:6001
Bus 005 Device 003: ID 09fb:6001 Altera Blaster
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x09fb Altera
  idProduct          0x6001 Blaster
  bcdDevice            4.00
  iManufacturer           1 Altera
  iProduct                2 USB-Blaster
  iSerial                 3 91d28408
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              150mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2 USB-Blaster
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Status:     0x0000
  (Bus Powered)
USB Blaster clone
Bus 005 Device 002: ID 09fb:6001 Altera Blaster
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            4.00
  iProduct                2 USB-Blaster-ARM????
  iSerial                 3 8D8C41695350
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              150mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2 USB-Blaster-ARM????
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  (Bus Powered)
For both USB blasters, this is the udev configuration.
$ cat /etc/udev/rules.d/51-usbblaster.rules#  Altera USB-Blaster for Quartus FPGA Software
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666"#  USB-Blaster II
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666"
If you need any additional info, please let me know.
    I've done some tests with several USB hubs, but same results...
    Now I've got an official Altera USB Blaster and "sudo lsusb -v -d 09fb:6001" shows exactly the same that DE2.
    I think I'll contact my clone vendors to ask them to check/correct this. The only difference shown in lsusb between the clone and the original is:
    bMaxPacketSize0: 8 (altera) vs 64 (clone)
    iProduct and iInterface: USB-Blaster (altera) vs USB-Blaster-ARM???? (clone)
    iSerial: 91d28408 (altera) vs 8D8C41695350 (clone)
    bMaxPacketSize0 might make the difference. Do you think that iProduct, iInterface or iSerial might have any influence?
    Do you want me to go on revere-engineering my clone?
    Thanks a lot!
    --- Quote Start ---
    Thanks a lot!
    --- Quote End ---
    Wow, I'm having the same problem as you.. on Win8 it runs fine, on Linux.. It doesn't. It recognizes my cable, I'm able to run once jtagconfig, then it doesn't work anymore and I have to remove and insert back the cable. I'm able to program my device, but to call a tcl with Signal trap doesn't work.. please can we try to reverse engineer it?
    the output from my dmesg:
    [20062.358849] usb 3-2: new full-speed USB device number 8 using xhci_hcd
    [20062.370796] usb 3-2: New USB device found, idVendor=09fb, idProduct=6001
    [20062.370807] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [20062.370812] usb 3-2: Product: USB-Blaster-ARM技术论坛
    [20062.370817] usb 3-2: Manufacturer: Altera
    [20062.370821] usb 3-2: SerialNumber: 8D77536E5655
    it is a sainsmart, rev.C, like the one listed on their website. from the spec you can read something like:
    • ALTERA USB ByteBlaster
    • USB interface
    • FPGA/CPLD download
    • SignalTap II embeded logic analyzer
    • NIOS II debug
    Any difference between Blaster I and ByteBlaster?
    --- Quote Start ---
    --- Quote End ---
    Ok, lets see ...
    --- Quote Start ---
    --- Quote End ---
    Ok, what is inside the Sainsmart device?
    http://www.sainsmart.com/home-page-view/usb-blaster-download-cable-for-fpga-development-board.html
    Remove the outer shell and read the part numbers on the devices (perhaps your version does not have the TQFP part number removed).
    Cheers,
    Dave
    --- Quote Start ---
    Ok, lets see ...
    Cheers,
    Dave
    --- Quote End ---
    Well I think my version is exactly like the first one posted here:
    - TQFP-48 I can't read the model.
    - 8 MHz XT
    - 74HC244 octal buffer
    - AMS1117 3.3V LDO regulator
    - 2x LED
    - Resistors and capacitors.
