13 years agoWhat do you mean by "some problems"? I have some problems with Signaltap under Linux with an EEBlaster. I can use signaltap, configure the triggers, it triggers at the correct time but the waveforms reported don't look correct, as if there was a shifting between the different signals.
AFAIK it is a problem in the FTDI driver in Ubuntu. The EEBlaster uses different FTDI chips than the USB Blaster. It shouldn't be a problem, and actually it isn't under Windows, but with Ubuntu we have this strange behaviour. From what I've heard this doesn't happen with Red Hat Linux.
