signaltap state trigger false positive
- 5 years ago
I dropped this back to a simpler filter and got it to work
Condition 1 : data = 3dcccccdh
Condition 2: address = 403xh
Condition 4: address = 683xh
Trigger on Condition1 && !Condition 2 && !Condition3=4
This won't catch a 4 byte data shift but it will catch an 8 byte or larger shift. That works for now.
Thanks for all your help.
Thanks for the response. Under normal operation I'm getting a trigger every 1 ms, and I have to collect data for many hours before the error occurs, and it sometimes occurs for a few seconds, then recovers for a few seconds, then occurs again... It seems like with your technique i would need a 2nd level of filter to throw out the normal triggers or stop collecting after I get a trigger on an abnormal address. That especially doesn't help because currently i can only capture 512 cycles of my SignalTap clock; I could maybe break that down to about 32 segments of 16-cycles each.
You may have pointed me in the right direction though. I had set my 'storage qualifier' to state-based, but missed that there was a 'Trigger flow control' down below that was still set to 'continuous'. I changed that to 'State-based'. Unfortunately now when I compile I get these cryptic error messages:
Error (272006): Invalid Signal Tap custom flow control description was specified.
Error (287078): Assertion error: Valid clear box generator not found or Errors encountered during clear box generation
Error (12154): Can't elaborate inferred hierarchy "sld_signaltap:auto_signaltap_0|sld_signaltap_impl:sld_signaltap_body|sld_signaltap_implb:sld_signaltap_body|sld_ela_control:ela_control|sld_ela_trigger_flow_sel:\generated:ela_trigger_flow_mgr_entity"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 27 warnings
Error: Peak virtual memory: 4912 megabytes
Error: Processing ended: Wed Dec 02 23:44:23 2020
Error: Elapsed time: 00:00:15
Error: Total CPU time (on all processors): 00:00:22
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 27 warnings
Any clue where I go from here?
No, that's the beauty of the segmented buffer. Just let it sit and every time the trigger occurs, one segment fills, even if it's hours between the trigger events happening. You could certainly add a second trigger condition for further filtering if necessary.
As you found, state-based can be set for the trigger flow itself and for storage qualification, which I've always found weird because with a state-based trigger, you can selectively choose exactly which samples you want to capture. In any case, I don't know if that's what's causing the error, but if you want to use the state-based trigger, set the storage qualification to Continuous and the trigger flow to state-based. You can also use a segmented buffer with the state-based trigger by using the segment_trigger command in the "code" instead of just "trigger."
- JohnDuq5 years ago
Thanks. it looks like when I had 'Storage Qualifier' set to 'state-based' and Trigger set to 'state-based' it caused the errors causing SignalTap to not be instantiated. At least I can compile again.
Now back to debugging this flaky trigger...
