11 years agoSignaltap retrieve data .... after having plugged JTAG
is it possible to plug the jtag (usb blaster or other) and retrieve captured data (aquire data a postiori) with signaltap? I mean : Program a FPGA with SignalTap, Let the board functio...
11 years agoWhy not just leave the USB-Blaster plugged into the board? That way the USB-Blaster is not "hot-plugged" into the JTAG header while your board is powered.
You could leave the USB-Blaster plugged into a PC, so that the cable electronics is also powered, but that is not required. You could just plug the USB-Blaster USB connector into your PC after the board has been powered. SignalTap II has a power-on trigger configuration. This allows the FPGA instance of SignalTap II to trigger, and then you can retrieve the trace at a later time. I have used this to capture an event that would only occur every few days. Cheers, Dave
